RED Starter Kit
Miltos Pilalitos
51
Athens, Greece
www.pilalitos.com
Hoping to make it financialy until Jan.21-24 and join the RED family/cult/believers i realized i don't know if the $17500 and a lens set will be enough for me to start shooting stuff when they arrive.
I am sure this information is somewhere burried around the 3 basic RED forums but couldn't find it here or red.com.
I understand there will be an HD lcd monitor in the package but not sure about batteries or (more importantly) storage mediums. Will RED ship with a REDFLASH or REDDRIVE? Will we have to add those to the cost?
Also, will the lcd monitor be mountable on the main RED body somehow or will we need the REDCAGE or something else for that?
Miltos
- REDDRIVE (mini-raid) is said to cost under $1000 (for 320GB)
- REDFLASH also separate (32 - 128GB - starts at for under $1000)
- unclear if REDFLASH port will ship with camera
- REDCINE software said to be free for reservation holders (to change?)
- batteries - don't know.
- LCD monitor said to mount anywhere, but I would at least try to buy that little handle which has extra mounting points.
Lots of info here:
http://www.hdforindies.com/2006/12/red-update-much-bigger-red-drive.html
http://www.hdforindies.com/2006/11/hd4nds-exclusive-big-red-update-part-2.html#links
http://www.hdforindies.com/2006/11/hd4nds-big-red-update-exclusive.html#links
____
Edit - whoops didn't see you're post Evin
Well, I may be opening myself up to some major ridicule but here is my half-assed Red budget. Many, many, many guesses and assumptions follow.
For clarity (and self-preservation) all (silly) RED-assumptions are in RED.
TIER 1
________
$17,500 - RED ONE -
$1,750 - RED RAIL -
$250 - RED HANDLE -
$2000 - 2X RED DRIVE -
$1500 - Shipping & Customs from USA
$750 - RED NIKON LENS MOUNT -
$2,500 - NIKOR LENSES - (Nikon 17-35mm = $1,959 Canadian)
$1000 - MATTE BOX / FILTERS -
$1250 - BATTERIES -
$1250 - Tripod
$500 - Camera Bag & Raincover
$750 - Mic and cables (mixer?)
__________
$31 000 - Tier 1 Total (US$)
__________
TIER 2
_____________
$9,500 - RED ZOOM
$750 - Red Rock Follow Focus
$1000 - RED FLASH or 3rd RED DRIVE
$1000 - RED CAGE
$2,500 - RED EVF
$750 - Shipping & Customs from USA
____________
$15 500 - Tier 2 Total (US$)
__________
TOTAL TIER 1 + 2
____________
$46 500 - Tier 1 & 2 Total (US$)
__________
If anyone feels like correcting any of the above numbers expect to get one of two responses:
1.) "Thank God :) "
2.) "Sucks :( "
And yes, I plan to go second-hand on some things. Thanks in advance.
1.) "Thank God :) "
2.) "Sucks :( "
My interpretation on the numbers are a little different;
$250 - RED NIKON LENS MOUNT (I'd hate to pay $750 for a lens mount)
$5000 - Tripod - Oconnor 1030HD (Of all the things you'd buy you wouldn't want to go cheap on the tripod. Red may push into the 18 lb. range)
As for the Red Rock Follow Focus, I own one and would sadly have to say, it just doesn't cut it based on the amount of play it has on its gear. I would strongly recommend picking up a Chrosziel follow focus, costs around $1,500 but no play, just smooth controlled reliability.
The Red Rock Follow Focus play is now fixed in all new devices shipped and even the old ones can be fixed - more or less - easily.
We got an $2k Arri follow focus because we also considered the Red Rock Follow Focus unusable but after the fix it works equally well.
The Red Rock lens gears also work with the Arri follow focus btw.
Cool, wasn't aware of an upgrade to the internals of the RR Follow Focus, I'll have to check into that, thanks! :)
The only problem now that I see with using the RR Follow Focus for a Red/Nikon lens setup would be the 15mm rod supports used for the RR and the possibly larger rods that will be used for the Red Rails.
Thanks Mike,
I will try to fix my RedRock follow focus today.
Alvice, Mile Mile Grazie,
I see Brian Valente is targeting jan 15th for the upgrade to be available.
That's a good point - any word on which standard the RedRail will adopt??
I would imagine for a camera this size they *will* go for the 15mm "video" standard - it would also be helpful in that accessories tend to be cheaper for that standard too...
I am not sure what the rod standard size and distance apart are for ARRI and other film cameras but I suspect with RED shooting for a production level camera with a PL mount they will adopt this standard. Anyone know what that standard is?
Jim previously said that You have the option of using 19mm, 15mm studio or 15mm lite rods. So it is all dead standard.
Martin
Martin
Yes the spacing and rod diameters will be industry standard but what option will you have for horizontal and vertical shift for lining up matte boxes with various lenses?
The Arri FF-4 follow focus we have has support for both 15mm and 19mm rods (see here). So it works on the P&S Mini35 15mm rods (when we use the cam shoulder mount) as well as on the 19mm Arri rods (tripot mounted).
I hope that the Red Cage supports both 15mm & 19mm as visualized in earlier renderings so I can use the Red Rock FF alternatively.
Martin
I wish it were that easy Martin. You bring in Aaton Arri Panavision and each has different rod spacing and placement standard so there unfortunately is no such thing as "dead standard". This is why when you see a HD camera with 35mm lenses it is frankensteined together. This is why I suggested RED may adopt the Arri/Arricam/Moviecam standard because it seems to have the most aftermarket options available.
