- Banned
- #21
Gbabymogul
Banned
- Jan 1, 2007
What gives you "REDCODE"? (Not REDCODE RAW?)
I assume anything that's not RAW - REDCODE RGB 1080p, REDCODE RGB 720p. BTW - #6 & 7 ? Nice
Thomas: why not do the conversion in REDCINE yourself? Just ask for the original camera negatives and process those yourself.
offhollywood: if you can export to REDCODE then that should work. But that is a different REDCODE than REDCODE RAW which is what the camera generates (and is loadable *in to* REDCINE)
Obin, you're missing the point of what REDCINE is. It's not a colour correction application. It's primarily a RAW converter, and it has controls needed and required by a RAW converter. Also, the beginning of the workflow, where REDCINE is used, primarily, is not the place where you normally do advanced colour correction.
Thomas: that's possible as well if they can load a QuickTime file (have to be careful to get more than 8-bits per channel though) or you can export something like a DPX sequence from REDCINE without doing any processing to the footage at all.
offhollywood: exporting to the QuickTime codec will give you that.
We are still finishing up all the post workflow tidbits, it's quite complex (behind the scenes). We will come out with a clear overview (picture?) once it has all settled.
As it looks now REDCINE will import all files generated by the camera and no doubt recordings made on the RED-RAID in the near future. It will not load your own generated REDCODE files.
PerfectOptics: no, not color correction in the traditional sense of the word. That implies much more and different controls. The application does have color controls but these are meant (together with the other controls) to get the image in the right range before further processing. Just like a one light in film terms: http://en.wikipedia.org/wiki/One-light
It indeed operates like other RAW converters, but on moving images.
For final color correction & other post effects you want to use tools more adapted to do that, like 3-way color correction, secondary color correction, power windows and so on.
I can only hope that some new 4K 3-way color correction w/ secondaries moves down into an accessible range - within Final Cut Studio would be nice
Shake could hold me over but I'm just hoping a more streamlined option appears.
On this mysterious timeline that we'll see at some point... what will happen after pushing an EDL through REDCINE? Once we have our online picture lock coming out of the app for final color work... will that be entirely up to us or will there be some RED [or inherently REDCODE compatible] solution? I keep having to stomp out my inner rumor-monger every time I see Apple make a big move like buying Silicon Color... if only there was some RED-Apple collaboration![]()
p.s. keep in mind there is a difference in working real time on a preview proxy from 4K versus working on an actual 4K images. David has indicated as well that just the debayer on a 4K image is already very expensive (time consuming)
I know you guys are competing with Cineform in a way but also that David Newman is under a NDA with Red. That makes me hope (and I guess a lot of guys here) that Cineform will still be treated as first class citizen and that a lossless conversion from REDCODE RAW to Cineform RAW will be available in REDCINE.
Not that I want to pay Cineform e.g. $2k for fun... But if I get all the real time effects I now have for 1080p available for 4K - those $2k would definitely be the best investment ever, after the $17,5k for the Red One of course![]()
I have never been a fan of having all my finishing tools in my NLE while editing, just makes it all cumbersome in the end, especially when you're doing long form.
I guess the word 'proxy' is wrong. Funny thing is we had internal discussions about this word. It's not a separate proxy file. It is indeed a 'preview' instead of a separate proxy. We are talking about the same thingHowever we aren't working with a proxy, the entire image is present (up to 4096 by 4096 -- the codec can hold more, yet most NLE tools can't.) We all know we won't "preview" to that resolution for a few years, but previewing at 2K in multi-stream real-time is doable today. When the playback is stopped, scrubbed, or zoomed in, all 4096 pixel data is demoasiced and presentated (on the fly.) This is important for any effects work that requires access to online resolution and data.
Very interesting. I think the thing I dislike most about FCS (and one reason I have yet to "make the switch" is because everything is separated. I love being able to have my timeline, apply realtime effects, text/character gen support, and color grading all in one place so if I want to change something - even something small - I don't have to render out, export to another app, render it again there, and bring it back into FCP. The only application I think should definitely be a standalone in the Studio suite is DVD Studio Pro, but that's just me. As has been said many times previously, choices are a good thing!I couldn't agree more. Final Cut Studio is a suite of applications - Final Cut Pro is just one of them. I'd want color control moved to a separate app.
Rob, what would you be looking at for when onlining 1080p/2K for colour grading and finishing RED footage ?For final color correction & other post effects you want to use tools more adapted to do that, like 3-way color correction, secondary color correction, power windows and so on.
