25fps to 23.987 fps on RCX
Kemalettin Sert
Los Angeles CA
www.kemalettinsert.com
we accidentally shot 25fps timebase instead of 23.98.There is framerate override option on Export settings if i set quicktime setting to 23.98 its gonna be same conforming like on cinema tools? learned from someone i should go cinematools and conform each clip (prores422) one by one and do this way which takes long..
whats the trick on this one fellas teach me easy way :)
Will you ever need to conform back to the R3D files? That might be a consideration to keep in mind.
Michael
Cinema Tools can batch convert too. You don't need to do them one at a time.
