Trent Lillehaugen
Red Team
- Aug 22, 2011
Single Spot or Center. I've tried continuous also.
Oddly, if I change the AF/M slider on the lens to M while in the Focus menu, the camera immediately switches off those options - so it's recognizing the lens.
Could the start button I'm pressing half-way be malfunctioning?
This is a very low mileage camera, so I'd be surprised it the button is having problems, but ... is there a way to test focus other than pressing 1/2 way - or test the button?
I've got a REDMOTE and the side handle, if they could be used.
BTW - a button on the REDMOTE to focus (as I'm often in another room monitoring thru HDMI) would be invaluable.
You can map any button (including one on the REDmote) to start auto-focus:
1. Goto: Settings->Setup->Keys
2. Goto the "Key Mapping" Tab
3. Press the key you want to map (say REDMOTE user A)
4. A list of events for that key will appear (for most keys this is just the press and release events)
5. Map the Press event to: "AF: Start"
