Savva Svet
While not war, when I've rigged up for festivals where I needed to be mobile, I've gone with still glass that I put focus gears on.
However, if I was going to go PL for this type of subject matter I'd would likely focus on the Canon CN-E 30-105mm or the Fuji 19-90mm.
The Canon is an interesting choice and fairly lightweight, 4.8lbs. Also that bit extra reach at 105mm might allow for more intimate frames where you can't get too close when compared to say a mid-range zoom.
On the Fuji front, well the Cabrio has the motors and controls for iris, zoom, and focus. It's pretty much designed for work like this. It's got it's quirks, but is a hell of a lens.
If you want a "banging" two lens kit adding a Zeiss CZ 70-200mm would get you that reach. Or going with say the Canon 70-200mm and having the IS on the lens might help keep this steady if you're on the monopod or shoulder.
Was going to say the exact same thing...but I'd push the Fuji even more for it's weight and image.
