Jeremy Wiles
- Nov 17, 2008
- West Palm Beach, FL
- www.kingdomworks.com
Over the past 10 months I have been editing a very large project using Premiere CS6. I've pushed Premiere CS6 as far as I could, but it just can't handle large projects. The project is over 15TB and Premiere has to load almost 4,000 files/clips when I open it. It actually opens quite fast, but editing is a nightmare. Thinking it was hardware problem, I built a brand new editing system and $15k server. I also now have a Red Rocket card, which I didn't have before. There has been little change. As the project has grown in size, I can barely operate and playback has become so slow I could take a jog around the block before it starts - literally!
A main issue I believe to be causing the problem is the multicam function within Premiere. I have 5 cameras at 5k resolution in the multicam. If I try to playback a timeline that has just a few minutes of multicam footage, it takes several minutes before playback. You just can't get into your "groove" when you have to wait this long. I have 6 timelines that are each about 1-hour long. To make a change on any of the timelines, I have to cut the footage and past it into an empty timeline, make the changes, cut the clips and paste them back into the original timeline. What a waste of time!
I'm at the point where I give up. I'm not a fan of switching to CC. Will the update to Premiere CC fix this problem or is it better to switch to Smoke? How does Premiere CC or Smoke handle really large projects and multicam footage?
Thanks for your time.
Jeremy
Jeremy
