michaellines
Active member
- Nov 17, 2008
I've searched and not found any resolution on stop motion using epic with the redmote. has anyone been successful doing this? thank you
There are 2 ways to do this (in version 4.0.x and later)
1. In the Recording Dialog you can set the recording to a limit of 1 frame. When you hit record a recording will start, take 1 frame, and then end. This will create a new clip for each frame
2. In the Recording Dialog you can set the mode to "External Frame Trigger". You will then need to map a key to "Record: External Frame Trigger" (e.g. side handle key A). When you hit the record button you will create a new clip. Each time you press the side handle key A a new frame will be added to the clip. Press the record key again to end the clip. With this mode you can also have it take multiple frames per trigger (like a burst stills mode).
Shutter count
This. Although I think Fantastic Mr Fox it was they shot with a Nikon DSLR stop motion. Although for a $40m film you can probably afford a couple spare DSLRs should you actually wear out a shutter mechanism!
I just shot a stop motion piece and considered using our Epic, but in the end using my 5DMK2 just made more sense. I used dragonframe, which is amazing software if you haven't checked it out. Even if you're shooting with an Epic, it has some really nice tools to make stop motion easier to shoot and get right the first time. We ran my 5DMK2 off AC for a solid 10 hours and it didn't have a single problem, no noise issues and the shot was perfectly consistent all the way through. One other benefit to use dragonframe is the incredibly fast turn around time. We shot all day and edited as we went. At the end of the day, we had the piece in FCP edited and ready to go.
