Rick Augustus
I'm new to Final Cut Pro X, and am trying to figure out the best way to export the highest quality video. Can someone please help me with this...
If I am not mistaken, when you use the Master setting in the timeline Share menu, you automatically use the highest quality clips in the output. (Can't recall off hand just where I read that.)
I'm not sure if this is correct, Terry.
I could be wrong, but I think Master File settings connects with whatever you put as a render setting of your timeline/project.
So if your render sequence is a Prores LT, the default settings in your Master File tab will be Prores LT.
I think the Logic of the program is that then it can use your (potentially) already rendered footage for a quicker export.
But it's in that same settings tab that you can change it to Prores 444 or Uncompressed though.
