Ketch Rossi
- Jan 10, 2007
- Sardinia, Italy
- www.afroditefilms.com
Okay, I wanted to post this here as well, as there is really something to be said about having a Great camera were even when life trows S^% at you, and you can only afford the absolute cheapest glass there is to go with your camera, which might be the last thing you posses and don't want opt sale...
Don't despair... There is always light at the end of that tunnel!!
And here you must take note that this shots were all hand held but one, and that there were shot on available light, at stops of 16 to 22, really at the worst of any lens right next to shooting WO on cheap lenses, yet I was very pleased with it, Focus also was done on the go manually (Rokinon do not have any AF and have no electronics in them for confirm focus either) so I am confident that on my next shot this lenses will bring a good result, and no one will ever say, oh that was hot on cheap lenses and does not look as good as if...
So, get what ever glass you can, and go SHOOT, your EPIC or Scarlet and of course even your R1 deserve it!!
Also to note that there is a very easy grading done to them, with time in and a good system to put it thru the paces this images would yield much greater results, I done this at a local Caffè since I was not yet set up at my new place in Modena.
And only this shot was done in this set up with the Rokinon 24mm @ 22
All other shots below were done with this set up using the Rokinon 35mm @16-22
BTW, I really did wish I had taken this with me, as the ET EVF mount by the end of the became heavy on my hand...
Okay, here the rest of the shots as I said all hand held manual focus Run n' Gun, literally, so I know in a controlled environment this combination will achieve much better results.
And this are form inside the Enzo Ferrari Museum in Modena.
