Posted here rather than to RED in case this helps others... (Scarlet, but applies to EPIC)
WANT:
To map a Preset to STILLS switch for single-frame 5K recording to SSD
PROCEDURE:
successfully mapped settings:
-12FPS
-59.9 shutter
-RC 5:1
to this
AND:
-want to also map:
PRESET>RECORD>MODE>CONTINUOUS RECORD> [x] LIMIT RECORD TO> 1-Frames
This would permit recording 1 frame still to SSD
PROBLEM:
Once above RECORD>MODE setting is set (and it works just fine BTW!), when I switch to my other presets which are set up for EXTERNAL RECORD (ie SSD must be dismounted, feed/trigger PIX recorder) - The RECORD>MODE can't seem to be mapped to set to:
RECORD>MODE>EXTERNAL RECORD ONLY
for these settings.
In other words. WHATEVER "RECORD>MODE>..." I make does not change when any other Preset is selected.
SO:
Either I am not seeing what PRESET>CAMERA PRESETS mapping button actually selects and modifies this function (there is no "RECORD MODE" choice that I can see in the mapping area of the PRESET MENU)
or
There is no way to modify this particular camera function
Thoughts?
Stu Aull
SX 199
Alaska
WANT:
PROCEDURE:
-12FPS
-59.9 shutter
-RC 5:1
to this
AND:
-want to also map:
PROBLEM:
for these settings.
SO:
or
Thoughts?
Stu Aull
SX 199
Alaska
