Richard Bradbury
- Mar 21, 2008
If you monitor in Rec709 and then flick to Raw View using an assigned EVF button, when you switch Raw View off again you are switched to monitoring RedSpace. To get back to Rec709 you then have to go through the menus, which is slow and annoying. Obviously if you are monitoring RedSpace this isn't an issue, just with Rec709. I'm on v3.2.5.
