I can vouch for both the RedRock remote follow focus and the Paralinx Arrow. They are both solid products from good companies. Shooting in LA, I've encountered a couple of "noisy" locations where their ranges were subverted, but these are the exceptions rather than the rule (and I suspect any wireless products would have had similar challenges in those cases). Teradeck, RT Motion, and Bartech all have great reputations as well, I just don't have first-hand experience with them.
Redrock
Like - Build is solid, good torque, smooth motion, quiet motor, cool accessories (finger wheel, microTape), price is right, good communication from company
Don't Like - Single channel system, still haven't delivered iPhone app years after showing it off, occasional signal drops/range loss in noisy RF environments
Paralinx
Like - Small, light, well built, very little lag, full 1080, multi-receiver support, good range, low power consumption, great price, great service from company
Don't Like - HDMI means problems co-existing with the +1 module, but I don't have a +1 so no problem; occasional signal drops/range loss in noisy RF environments
Last year when I talked to them at NAB they did specify it will drive MOST Cine lenses. This all depends on the stiffness of the focus rings which in some cases can require quite the torque that the RRM motors won't deliver (some older primos). They did advise however, because it is more less an "open" system, that it will interface with other motors that have more torque (heden i think is one they mentioned). Hope this help.I normally don't like Redrock products but I will check out their wireless FF at NAB. Can it handle larger cine lenses too?
I've been looking at this system for a while and i'm just trying to find an excuse not to pull the trigger on it. (its harder after this proline purchase to resist, lol) I will be asking the RR guys a lot more questions at their booth this year, so if you have anything you would like to know, I would be more than happy to help you ask
If you will be there too then I will most likely see you at their booth at some point.
with the sun hood? of course. Without one in direct sunlight i can't see a thing even on 800nit MarshallNow if you tell me that you can see in direct sunlight with 150 Nits , then you are a very lucky man with very good bright eyes.
I've used them on ENG shoots and the great thing about most of them is they allow hot swapping batteries. Not sure if the one in the link will do it, most do. love the way these work.Just wondering if people think this sort of "side by side" V-Lock battery hanger might be of use? Enables swapping out of individual batteries, not just "the one on top". haven't seen this arrangement before, personally.
http://pro-x.en.alibaba.com/product/355689762-210599522/V_Mount_plate_for_2_batteries_GP_TS.html
Anyone seen the Convergent Design Odyssey 7.
7.7" OLED with 1280x800 resolution, 8-bit (sounds awefully similar to the SmallHD panel), touchscreen
It adds waveform and RGB parade (compared to AC series)
It also doubles as a recorder for various raw formats (where you can rent licenses on a day-to-day basis)
SDI-I/O and HDMI I/O
For the price of $1290.
Yes it's the same panel as the smallHD guys. But for steadicam it's so reflective and not very bright.
I suggest people have a look at the Lilliput 663/O since it has native 720P resolution. I ordered mine about a week ago. Will post my thoughts on it when I receive it.
Did you manage to buy this ? I'm thinking of buying either the Lilliput 663 O/P or the smallHD AC7.
Both seem to have the same spec. I'm sure the smallHD probably has higher quality but the Lilliput 663 also has some advantages not found on the smallHD - for example is has color peaking not only on black and white (grayscale) image but also on the color one. smallHD seems to offer this feature only on their newest much more expensive monitors.
Can I custom zoom in on either Lilliput or smallHD ? I know I can zoom in by fixed numbers like 2x zoom and 4x. smallHD has the custom scale function but I don't know what that does. I would like to zoom in so for example I would see only 90% of my picture. The rest of 10% would be cropped out.
Is this possible ?
