Victor Nguyen
- Jul 2, 2012
I apologize for this novice question. Which do you prefer, using one or multi-camera and what's the reason?
As with the transition from film to digital, all cinematic storytelling will shift towards multi-camera as software and technology improves. Lighting isn't really the issue.
I agree. I think shooting A&B cameras to provide -- say -- a simultaneous 2-shot and a close-up can work fine, done from the same direction. What makes me crazy is when directors try to shoot a wide and a tight at the same time, or cross cameras to shoot close-ups of two characters facing in different directions. This is just bad blocking, period.As has been said, single vs multi is lighting vs continuity. If multi, I generally do NOT go for two or three different angles - more wide, med and close. If you do for more angles, unless your lighting is 'fat and flat', like a TV sitcom, there can be issues - one side of the face flat and bright, the other dark.
And with Dragon, it should be easily possible to get 4k footage from the ample 6k sensor.
That's true. But I'm talking about different angles and how that will affect compositions and lighting.The OP didn't constrain the discussion by specifying camera so I'm thinking I can cheat by using one camera with high resolution (Epic) and give the finished output the look of a multi-camera shoot. That is, I can crop different sizes to go CU, medium CU and all points in between from the same footage of an establishing shot And with Dragon, it should be easily possible to get 4k footage from the ample 6k sensor.
It's a lot better (and easier) to just frame the shot correctly while shooting. Small errors in framing are fine, and those can and do happen sometimes. But I wouldn't go into a show on the assumption that you can reframe every single shot, or get a medium shot out of a wideshot, because then sharpness will constantly change shot to shot -- more than it will ordinarily, just with different lenses and depth of field.That is, I can crop different sizes to go CU, medium CU and all points in between from the same footage of an establishing shot And with Dragon, it should be easily possible to get 4k footage from the ample 6k sensor.
... But I wouldn't go into a show on the assumption that you can reframe every single shot, or get a medium shot out of a wideshot, because then sharpness will constantly change shot to shot -- more than it will ordinarily, just with different lenses and depth of field.
