chris morgan
i've been digging around on forums across the 'net trying to get a little insight on this question, but haven't quite figured out a solution.
as i work more and more with my scarlet on various projects, i find that i still don't have a consistent workflow for finalising and grading. this is largely because i end up doing some level of VFX during the process, as well as mildly to strongly denoising most shots using neat video.
i have neat video for AE, so usually send my PPro project to AE using the dynamic link, and denoise my shots (in addition to doing any VFX work). keep in mind that i've done my basic exposure and WB adjustments inside RCX / PPro, and i'm working with the files in RedLogFilm.
my question is... what's the best way to preserve the most latitude from this point going in to resolve? i assume a dpx sequence will do the trick, but perhaps that's overkill for the secondary / final grade...
i'm presently doing an export using the apple animation codec, and will see how that holds up.
i'm guessing the short answer is to upgrade to the full version of resolve (which will be happening in the coming months) and do denoising in there, or perhaps to denoise post-grade, but again as i've got resolve lite i'd then be working with 1080p files, and i also operate under the belief that power window tracking and grading generally works better on denoised footage.
any insight from more powery-wowery users would be great!
cheers,
chris
cheers,
chris
