roryhinds
- Jan 15, 2007
- Vancouver, BC, Canada
- www.minefilms.com
are we still to see a RedRay Pro device or has the "pro" version been scrapped ?
Don't expect BD quality out of 20Mbits 4K encodes- REDCODEC is not more efficient than AVC and Blu-rays are encoded with 20-35Mbit for HD res using encoders designed for this, with tweaked segment encodes over 2 or more passes. Relatively it will be way <BD quality- there is no magic and as much as RED can do good encodes out of their encoder you can't win with math![]()
Please inform me- happy to hear all great things![]()
Just curious - why this exciting player device called "REDRAY"? It feels more like projection devicewhy not "REDPLAY"? So projector is going to be named "REDBEAM"?
REDRAY will be built into at least the CRIMSON projector as well.
This unit is the standalone player and can be used in a wide variety of applications. In addition there are two laser projection systems - REDRAY Projector (consumer) and CRIMSON (theatrical); both of which include the same REDRAY 4K 3D engine, that will be formally introduced later.
next step up from Blu-ray.
I think it's fair to say that compression has come a long way in the last 10 years. I would be curious how long it takes to encode a 2-hour uncompressed movie through RedRay to create the .RED files. And I also wonder how compressing a movie 5 times more than the current Blu-ray specs will look in terms of artifacts. Blu-ray can theoretically go up to 45Mbps in terms of bitrate, but rarely go quite that high; broadcast HDTV typically goes no more than 20Mbps, and it looks fine to my eye, assuming good mastering.Don't expect BD quality out of 20Mbits 4K encodes- REDCODEC is not more efficient than AVC and Blu-rays are encoded with 20-35Mbit for HD res using encoders designed for this, with tweaked segment encodes over 2 or more passes. Relatively it will be way <BD quality- there is no magic and as much as RED can do good encodes out of their encoder you can't win with math![]()
Are you talking about quality represented by this clip:
http://red.cachefly.net/Tattoo2K.mp4
is this what you describe amazing?
I started and found that 2.5MB refers to .RED format, so I removed wrong (assumed) info.
Lets ask RED team- what are the typical PSNR values for new 20Mbits codec?
..Blu-ray can theoretically go up to 45Mbps in terms of bitrate, but rarely go quite that high; broadcast HDTV typically goes no more than 20Mbps, and it looks fine to my eye, assuming good mastering.
It would be a miracle to see a 4K movie compressed to under 100GB, but I'd love to be surprised.
