brian mcclatchy
- Oct 5, 2008
- Germany & USA
- www.brianmcc.com
I am working on some rather large natural history projects with over 20TB of original Red Epic footage for each 52 min show. We have started editing the files natively in Premiere Pro CS6 and the actual editing is going quite smoothly on our Mac Pro.
The biggest issue I am coming up against is organizational.
So far i have not found any way in Premiere Pro to view much of the metadata that is already present in the original files viewed in RedCine.
Is there a way to display all the metadata in Premier that is already in Redcine?
Even simple things such as Record Frame Rate, Rating and Redcode compression dont seem to make it into Premiere.
Am I missing something?
The next problem is that when searching for key words in logged footage Premiere only displays the next clip that matches the keyword and not all clip at once. Is there any way to create a bin with all logged clips that have a common keyword in the description for example? This seems like a pretty basic function that is missing and something that is quite easy in Final Cut and Avid. Any ideas?
Ultimately I would like to incorporate all the logging info into some kind of footage archive with functionality similar to Lightroom 4 but that doesn't seem possible at the moment. Any tips on a better system to log R3d footage and use that information in an edit as well as in a footage archive at a later date?
Ideally I would like to have a system that i can use in the field on a Macbook Pro to view and log r3d files that can then be imported into a Premiere Pro project to edit.
thanks for any ideas - Brian
