Hmmm.... I have to disagree with these common results to some extent. I think the EPIC's biggest fault is not that it's less sensitive or that it doesn't have the same great color reproduction. Both of those statements are untrue. However, they are true within the context of these tests when comparing video right out of the camera. EPIC video, or anything shot with any RED camera, needs a helping hand in post. There is also a fundamentally different approach to how RED interprets its respective color and luma curves at ISO 800 (or any other EI) compared to how ARRI or SONY are doing it. Doesn't make it wrong or right, it's just different.
We tested Epic, Alexa and F3 against each other under identical conditions at the Ludwigsburg Film Academy last year. The complete results were published in Digital Production (Munich).
Very short excerpt:
The Epic is the least sensitive and has the highest resolution.
F3 and Alexa are more sensitive. Alexa and Epic have much better colors then F3.
Yes, the Tiffen Hot Mirrors are the best if you shoot with 0.9 ND or more.
Yes, Abel Cine is a very competent company.
Yes, we own one Epic and two Scarlets instead of one Alexa. And some Hot Mirrors.
Hmmm.... I have to disagree with these common results to some extent. I think the EPIC's biggest fault is not that it's less sensitive or that it doesn't have the same great color reproduction. Both of those statements are untrue. However, they are true within the context of these tests when comparing video right out of the camera. EPIC video, or anything shot with any RED camera, needs a helping hand in post. There is also a fundamentally different approach to how RED interprets its respective color and luma curves at ISO 800 (or any other EI) compared to how ARRI or SONY are doing it. Doesn't make it wrong or right, it's just different. And the beauty of shooting RAW is that we have complete control over how all those properties are interpreted if we don't like it. Comparing color reproduction on a RED camera vs. the same on a camera shooting a baked format is an apple and orange comparison. I do agree though that the default color science on the RED's still isn't as pleasing as what ARRI and Sony are doing out of the box. But in post I can match the look of the Alexa any day and do it all the time. I believe Mark Toia posted some Alexa/EPIC matching samples around here somewhere I think it was him. Even ARRI-RAW doesn't give us a fraction of the level of control we have with RED. That's a double-edge sword in some ways -- it's awesome to have the level of control we do with the R3D workflow, but for the uninitiated it can be overwhelming and it's easy to mess things up until you get the hang of it. I've found that while correcting R3D or tweaking in post, less is usually more. A few very subtle changes are all that are needed to make the clients happy.
The real sticking point I have is with the Tiffen filter claims. I've found otherwise. The Tiffens always get full marks and seem wonderful in my studio/lab tests. In real-world shooting, not so much. When I'm in the desert in the middle of July, with large rocks or sand dunes radiating IR as if they were some form of energy beacons, I consistently have better results with the Formatt and Pancro filters. The Tiffens do seem to hold up better at low to moderate IR levels and they have more neutral or clear color properties vs the Formatt IRND's, which are a bit too purple. Simple WB corrects the color cast, but in extreme IR environments, I've found the Tiffens fall short. I would say that 65% or more of my shooting is outdoor, EFP, lifestyle type shooting for corporate clients. IR filtration and heavy ND are a way of life for me, and much of it is in very intense IR and UV, high-alpine environments, desert heat, etc..
Maybe what I'm trying to say is the Tiffen filters look great (as if they're not even there) while blocking relatively low amounts of IR. The Formatt and Pancro filters do a much better job at blocking more IR, especially in intense environments, but are not as color-neutral.
