Tobias Buehler
- Apr 21, 2012
After seeing what you can get out in Photoshop/Lightroom with BMCC dpx RAW files i feel there's no direct way you can get the most (visible) dynamic range from the footage in Redcine-X.
What I'm missing is options like "shadow/highlight" or a better curves tool. For example when you lower the ISO to 50 you get nice tones in the parts that are blown out at ISO 800, but then the shadows are gone and vice versa.
It obviously records a lot of DR that you can't get into one picture without having to render 2 versions and luma-mask it as with HDRX. Actually I get better DR results when I adjust in Filmconvert than I can get in Redcine.
I feel like in Premiere, Resolve etc. the R3d's grade about as good as a Prores 422 proxies at the same meta setting, all the information in DR that's there, but you cant get out of in Redcine-X is just gone in most other natively .R3d supporting programs.
What good are 13 stops or so of DR if you can only decide which 4 or 5 of them you want to see?
Do I have a point or is there some ruler/option I totally missed?
