, prerecord mode... wanted...
Hi Hugh, I think there's something to do with variable frame rates that causes some problem because it's the same (infuriatingly!) on the Varicam - you can have pre-record on 25P but not in variable frame rate (ie native recording so when you view it it's in slow motion or whatever). And yet you can do it in 60P mode so it's obviously not simply to do with the amount of frames, more the process that produces the native slow motion.
Steve
Don't worry, the feature will be here in build 4.. Coming in December.
