+1 Monitor Adaptor
heh heh well don't give up complete hope.. alot of those guys have Miezler module or Pro IO on their list so many may pass on the +1..
LOL - I'll keep all fingers & toes crossed then!
The prototypes only work with Camera build 4 right now.... which is going to blow alot of your minds.
Build 4...Nice music to my ears. :-)
Timelapse long exposure and so on...
B.
If it's using the HDMI port, will I still be able to use the HD-SDI for client monitor?
Ideal situation has me framing with the EVF, AC using the LCD, and clients happily watching 50 feet away on a big field monitor.
Last time I checked you could use HDMI, or HD-SDI, but not both.
I also run my Atomos Samurai about half the time...
You have been able to use simultaneous HDMI and HDSDI for a while now.
my issue is that if it uses HDMI it would block the port for my Arrow transmitter and would make it a less than perfect solution...
I don't think anybody's mentioned it using the HDMI port...pretty sure it just feeds off of the module connection, like the Pro IO...
Email sent!
Also i've been in the mood for a good mind blowing! Bring on Build 4.
Where do you live again? If it is anywhere close you have a deal.. next one that gets built up in a week or two ill make sure you can take it for a swing for a couple days.
Email me Jarred@red.com
