A
Adam Welch
Guest
What is everyone using to mount a shotgun mic to their Scarlet? I have a Sennheiser ME66 and I would like to have the option of mounting it to my Scarlet if need be.
That is freakin awesomely nice! That is the cleanest looking mic mount setup I have ever seen. This should be seen by the aftermarket accessory makers and make that happen! I would buy that in a second.In a bit of symmetry I adapted the shotgun mount from my old Panasonic HVX on to the sliding handle of my Scarlet:
If you check the Nato Rail torch mounts they fit short gun mic's well and fit on top of an Epic perfectly well. They are not expensive and much better use than originally intended.
My only point is putting a mic on a camera is the last place it should ever be mounted.
I don't plan on putting the mic on a camera if I don't have to, just in case the situation calls for it. I have a boom pole and shock mount for most situation. I just want to be flexible.
What I did was simple, just drill out ONE hole in the base of the HVX-200's mount, it won't allow for two bolts due to the spacing but one bolt will hold things on if you tighten it down...like a man!
Then I just cut a screw down with a hacksaw and finished it up on a grinding wheel.
Puts it just over the mattebox, plus it looks damn near factory:
Typically it's for capturing ambient, again even in this config I'd still be most likely using a LAV mic or a boom, it's just another tool for the toolkit.
I've been both a DP and a Mixer and I don't think I could ever fly a boom and operate a camera at the same time. You must be Superman! Would it not be better to just have the boom operator do it, though?
