Trevor Meeks
Yikes, I apologize for asking in the forum for questions then.... I'm not a Senior Member, as you can see so, to me being brand new to this, it's a valid question and everyone's been beyond cool about prior questions -- until now. I scrolled through 15 pages under this forum heading and didn't see "this shit" being talked about, nor was it a 'sticky' topic.
Really, if you can't afford 3-4 64G SSDs, you can't afford a Scarlet. Sad but true.
It does not make logical sense that a scarlet is the price of two 512 cards. It would be nice to Add a few more SSD's
hence the new lower end cards that are soon to be out.
Where is there information about this? What lower end cards coming out soon? Elaborate ?
There's nothing fancy about RED SSD - it's standard off the shelf Toshiba SSD, costs maybe... guessing... $500 for 256GB in quantity?
Mike
Very well put.Ahh, but is it? Maybe Red have a deal to take all the best ones off the top at a huge premium, meaning by definition every other commercially available Toshiba is not up to the task? I used to work in QA, there is no such thing as off the shelf these days. Look at a Scarlet, it is essentially an EPIC that couldn't meet the QA spec when tested. Talk about a price difference!
We should not assume anything here. Red have no interest in ripping us off. I have tremendous faith and have for the last 5 years. So much so that I don't even need to ask. If they say they cost this much, that's the truth.
Simply not true. 64, 128 and 256GB REDMAGs are Toshiba's 3rd generation MLC Micro SATA modules that Toshiba has specced at 220MB/s for sequential reads and 180MB/s for sequential writes. Current consumer SSDs are much faster.
Confirmed.
BTW: Convergent Design sells 1.8" SSD's for their Gemini 4:4:4 Recorder.
512GB $1500
256GB $750
In my own testing the Convergent Design SSD's were faster than the RedMags...
Can you please share your testing method. Charts showing data results would be helpful as well. The problem with the results I imagine would be the inability to test the media in the opposing recording mechanism. In other words you can't test the RED SSDs in the Gemini and you can't test the CD SSDs in the RED. Therefore there's probably no way to say with certainty what impact the two speeds have on the actual recording process. Obviously there are minimum write speeds required but it's the optimization that is most likely having the biggest impact on each system's ability to record to that card with precision.Confirmed.
512GB $1500
256GB $750
