FS: LEICA R 8-LENS SET (19mm, 28mm, 35mm, 50mm, 80mm, 100mm, 135mm, 35-70mm)
Kevin Koniq
Active member
Hi folks - have a lovely Leica R lens set, not cine modded, all lenses are in good-great optical/mechanically and cosmetically fair-great condition, color matched against a Macbeth under the same conditions.
19mm Elmarit-R f2.8
28mm Elmarit-R f2.8 Super-Angulon
35mm Summilux-R f1.4
50mm Summilux-R f1.4
80mm Summilux-R f1.4
100mm Macro-Elmarit-R f2.8 Macro
135mm Elmarit-R f2.8
35-70mm Vario f3.5
Thanks,Kevin
SOLD
Hi Manuel - are the pictures appearing for you now?
Kevin, the issue is that you are cross linking an attachment from another forum. The simple solution is to upload them as an attachment to Reduser.
Phil - thank you for that tip, much appreciated!
