Scott C
I had posted a topic in the SCARLET section, but on this build, I cannot get 720p output at all. HD SDI or HDMI, neither works when set to 720p. Is this part of this build?
Got a call from set where they were using my camera on the 3.3 build. The DP reported that when they started rolling, 2 out of the first 3 takes were "glitching" or dropping perhaps a second of footage mid-take.. This was observed shooting, then confirmed from the in-camera playback, and from RCX-Pro (4k 24fps 8:1 on a 256GB mag, fresh firmware install, fresh format, fresh black-shade). 3.3 is a beta build, so no harm no foul - I just had them roll back to the release firmware, but I wanted to raise a flag so that Red is aware of the potential firmware problem. My camera is Epic-X SN 538. Has anyone else run into this?
Thanks,
Tim
Please open a support ticket and send in a log file. Even though 3.3.3 is beta we don't expect recording errors like this.
Thanks; when I get my camera back next week, I'll reflash to 3.3 and try to reproduce. Assuming I succeed, I'll get a ticket opened and forward the log.
Tim
The log file contains quite a bit of history (and survives across upgrades/downgrades). If you could get a log file from the camera sent to you and forward it to us it will likely have the info we need. Getting the associated clip names that had the problem will help pin point where in the log we need to look.
This is a (known) small bug where the display show the X-track in HDRx mode, instead of the base exposure. This was supposed to be fixed in the latest build - is that what You are running?
Hello all.
Just want to add some observations to Red's radar. I know this is beta, so this is not a complaint.
Just my five cents re. 3.3.3 (on Scarlet #986) :
- Spontaneous shutdown, happened 3 times today when going through menus
- Loud noise on analogue (cam) sound input 2, plus a loud 'tick' each second - independent from any specific audio setting, apart from level
- LCD does not always sync correctly and needs unplugging and rebooting of camera to get it working stutter-free on a 24fps project
- Video playback works for about 6 seconds and then starts slowing/stuttering down to a full stop within another 5 seconds; tried formatting the SDD: this is with compression at 6. Tried recording several clips on several SDDs.
Apart from the issues mentioned above (which i hope will be taken aboard) this is a great build! So many superb new options and surprises. E.g. the wysiwyg masked frameguide with variable opacity is absolutely great stuff!
Martin.
Just had a 4 day shoot running firmware 3.3 and had a few issues with my Scarlet.
- Sometimes playback would only show red color channel both on the image and on the histogram. This happened after changing to previous clip when in playback mode. And after it had happened it only seemed to be corrected by rebooting the camera, toggling between preview and playback didn't help (preview worked fine, playback kept showing only the red channel) and neither did skipping between clips. Didn't happen all the time, but often enough to be a nuisance.
- Two or three times when booting up the camera, the side handle wouldn't "turn on". The buttons didn't work and there was nothing on the display. After a reboot it worked again.
- I had this happen only once, but when the same camera was with another operator on a shoot before this one, the 5" touch screen would go dark and stop responding when toggling image magnify. HDMI out kept working and I was able to use the power button to soft power down the camera.
Should I open a support ticket for these issues and have any of these been fixed with 3.3.4?
Thanks for the new build!!!
Is fantom power not enabled in this build?
best
joe
