Paul Schneider
- Dec 28, 2009
- LOS ANGELES
- www.concreteandclay.com
Also. Def agree on the SSD. As for raid, I'm looking into that as well.
There's something wrong with your machine if you can only get 1/8 res playback.The stats on my new MAC PRO, are double of everything you have posted here, and I have a ROCKET and I don't get smooth 5k 1/2 res. playback on a full timeline. 1/8 res, yes maybe, if I'm not running anything else, and if the timeline isn't a mile long. If you get smooth 5k at 1/2 res without a rocket, either there is only 1 clip on your timeline or you pre render. Otherwise it's not true.
You don't actually want a 600 series nVidia card as the 500 series cards offer similar/better Cuda performance.If your getting a new video card I would go with a GTX 690, I mean it's fairly cheap and you get tons of video ram, and enough cuda cores to fill a small wheel barrow, and that's saying something!
Seeing how you need to choose Xeon to be able to have two CPUs I'd recommend the E5, too. But if you can only afford to build a system with one CPU, I'd definitely go for an i7.He recco's the newest Intel E5 chipset over the I7.
The higher speeds are generally due to the Sandforce or other controllers that compress.If you're going to spend the money on an SSD, the Intel 710 is not where it's at. The Samsung 830 and OCZ Vertex 4 are twice as fast.
Text, XLS, DOC, etc. - compresses well.
R3D files and other video temporary output formats don't.
So the higher speeds may be a bit misleading.
Also consider the Crucial M4. I was initially mislead by the transfer rates quoted by the other products.
This is indeed true -- SandForce controllers are some of the worst offenders. Not in their performance, but in the advertised speeds and marketing behind them. That said, I still stand by what I said in regards to the SSD and the speeds I quoted are pretty much on par with what you can expect from the latest batch of units on the market. Intel's upcoming 720 series of SSDs is also up there in performance too, but also in price. The OCZ Vertex 4 is the current king of the hill in 2.5" SSD's. Over 90K IOPS and it can still hold over 365MB/s for read and write on incompressible data. Samsung, Intel, Crucial and now OCZ all have done away with using SandForce controllers in their newer products. Samsung and Intel develop their own -- Intel 710 has an Intel controller, as does the upcoming 720 6Gbps units. The Intel 520, 310 and 320 series all use SandForce controllers. Crucial/ Micron have their own controller. OCZ bought out IndiLinx...
The whole incompressible data thing as it pertains to larger video files like R3D, H264 and similar is somewhat of a non-concern when the SSD is being used as a primary OS / system drive. You really won't be using it for workspace or to shuttle those sorts of files around. What you do want is consistent performance and a stable product, fast reads are a bonus. The newer controllers, including SandForce, are much better at cacheing and compressing data on the fly than before. Even "incompressible" data can be cached and/or compressed with other data on internal transactions.
The M4 is a great SSD. It's not very fast compared to what else is out there, read times aren't bad but the write times stink. That aside, iit's a solid and reliable product and makes a great option for a primary system volume containing OS and apps where read speed is the primary concern.
At least I am talking about realtime functionality while editing in Premiere. And unless a "full timeline" for you means that it has multiple streams of video playing back at once, then I'll repeat myself and say there's something wrong with your machine. My 2010 iMac easily does 1/4 res 4K playback on sequences with numerous edits and dissolves in Premiere and Resolve.For those of you saying there's something wrong with my system, you obviously did not read what I wrote. I'm talking about real time functionality not just one clip sitting in redcine. I'm talking about a full timeline. Anyone can have full 5k playback in redcine if they wait long enough for it to buffer. I have dual xeons 64gigs of ram, quadro 4000 and a rocket card.
I agree. Something definitely wrong. I get playback in Premiere Pro also at the resolutions I listed previously, and without a Rocket.
I have a love hate relationship with REDuser... There is so much drama sometimes, but I keep on being drawn back to it looking for posts that may help me in my endeavors.
Also the one and only problem with that computer is no RAID. You guys all talking about how my system is messed up or bunged or whatever you want to call it, are wrong. The only problem is the transfer speeds.
And that right there could be your problem. Why say you've got "double everything" if you don't have RAID, while Joseph - whose machine you were comparing yours to - has? The first time I tried R3D playback on my iMac I was underwhelmed by the performance, but after actually putting the media on a fast drive I got what I was looking for.Also the one and only problem with that computer is no RAID. You guys all talking about how my system is messed up or bunged or whatever you want to call it, are wrong. The only problem is the transfer speeds.
