Nicholas Matthews
Active member
- Sep 1, 2010
Stage set. Apologies for the oversight.
Yes, a blue filter like the 80C will reduce the noise in the blue channel if you can compensate for the light loss from the filter, which is actually cutting back on the opposite color wavelengths so that the blue channel is more equal or balanced, but the noise is improved only if you then compensate for the exposure loss from the filter.
However I don't think the blue channel is that noisy any more on the MX sensor, I'd only bother with the 80C for chroma key work or whenever you need a cleaner blue channel.
I am going to be doing my first shoot with a RED ( Scarlet ) coming up in July for 2 days. It will be a talking head shot outside durring the day using silks and bounce for lighting, perhaps an HMI if needs be. Since it will be my first time working with a RED ( FINALLY! ), do you have any words of wisdom, warnings, tips, etc.?
Thanks!
~Dean
I apologize in advance if this is slightly off topic.
Can anyone recommend a reliable company in Los Angeles or points beyond that services lenses? I have a set of Super Baltar primes that need a full CLA. They have been in storage for about 10 years and the lubricants have completely dried up.
My initial research has yielded the following candidates (Any feedback would be appreciated):
Duclos
Focus Optics
Visual Products
(or put daylight tubes in overhead flow and just turn one row or something).
You could try Kino 55 tubes or Chroma 50's, etc. I have found though that some older fixtures don't like Kino tubes so you'd be safer with the Chroma 50's, which are cheaper anyway. They have a touch more green in them than Kinos and are slightly warmer at 5000K instead of 5600K.
