Harrison Diamond
Guess I was lucky that I ran a Force_Upgrade because I'd updated my Redmote first
Hi Trent, I just tried mapping focus to the +/- side handle rocker, and it's amazing being able to pull focus while keeping a solid grip with both hands on the camera. The step size is a bit small, so the response is a bit to slow to be generally useful, however.
If there were away to alter the speed at which the rocker would move through the focal distances, you guys would really have a revolutionary feature on your hands. Being able to pull focus while maintaining a solid grip on the camera with both hands would be incredible.
That would be great!I like all your ideas. Speaking to number 4 we were thinking about adding the ability to assign a preset to certain camera events such as power up, start playback, start preview, etc. This should let you do some pretty cool things like keep separate record and playback key mappings.
We'll look into a good solution for this. Either allowing you to adjust the rocker repeat rate or allowing more control over the step size of the focus near/far actions.
Map a Key to Toggle or Cycle Through Different Settings
Goal
Add the ability to have a key cycle through a selection of ISO values. For this example we will have the Side Handle A key cycle through ISO 320, 800, and 2000
Solution Description
Create the following presets. Each preset will set the ISO to the appropriate value and remap the A key to apply the next preset:
- ISO 320
- ISO = 320
- Side handle key A mapped to Apply Preset: ISO 800
- ISO 800
- ISO = 800
- Side handle key A mapped to Apply Preset: ISO 2000
- ISO 2000
- ISO = 2000
- Side handle key A mapped to Apply Preset: ISO 320
Solution Step-by-Step Instructions
- Create a dummy camera preset named "ISO 2000" (we will explain why in the Techniques Used section)
- Open the PRESETS Dialog
- Open the CREATE PRESET Dialog by hitting the CREATE... button
- Name the preset "ISO 2000"
- Add any parameter to the preset (remember this is a dummy preset)
- Create the preset by hitting the CREATE button
- Create the "ISO 800" preset
- Map the Side Handle A Key to apply the "ISO 2000" preset
- Open the KEYS Dialog: SETTINGS->SETUP->KEYS
- Press the Side Handle A key
- Set the PRESS action to "Apply Preset: ISO 2000"
- Exit the KEYS Dialog
- Set the camera ISO to 800
- Name the preset "ISO 800"
- Select the following parameters and add them to the preset by hitting the --> button
- LOOK: ISO
- KEY: Side Handle User A Press
- Create the "ISO 320" preset
- Map the Side Handle A Key to apply the "ISO 800" preset
- Set the PRESS action to "Apply Preset: ISO 800"
- Set the camera ISO to 320
- Name the preset "ISO 320"
- LOOK: ISO
- Create the REAL "ISO 2000" preset
- Map the Side Handle A Key to apply the "ISO 320" preset
- Set the PRESS action to "Apply Preset: ISO 320"
- Set the camera ISO to 2000
- LOOK: ISO
- Done: Press the A key and watch the ISO cycle between 320, 800, and 2000
Techniques Used
This solution works since each preset contains both the setting(s) you want to control (in this case ISO) and the key action to invoke the next preset in the series. Since we want to cycle through a series of settings we have a circular dependency between the presets (which is why we needed to create a dummy preset to start the process). Note: the "Apply Preset: XXXX" action references the preset by NAME, which is why we were able to replace the dummy "ISO 2000" with the real preset and have things work correctly.
Trent,
I have been attempting to create a single button cycle for Exposure check/Video check/OFF, but no number of toggle commands in the string will turn off either feature. I tried:
1. Exposure check toggle for button press
apply preset advance to step 2 on release
2. Video check toggle for button press
apply preset advance to step 3 on release
3. Video check toggle for button press
apply preset advance to step 1 on release
I expected the second Video check toggle in step 3 to turn the feature off, but it does not. Suggestions?
It looks like your problem is that you are using the "Exposure Check: Toggle" and "Video Check: Toggle" actions in combination with this "recipe". What you want to do is follow my instructions for the ISO cycle and instead of setting the ISO and saving it in the preset, you want to set your camera into the correct mode "Exposure Check", "Video Check", and "Off" and save the preset with "False Color Mode" and your key mapping to transition between the different presets.
I hope this helps. When I get some more time I'll try to create the full set of presets and document it in this thread.
Trent this is awesome stuff. I've been a real advocate of the preset and customisation possibilities to date and this is now starting to feel very mature. Excellent work
And in the spirit of always wanting more, I'd love a web based utility that lets you set up this stuff with clickable buttons, dropdowns etc. to then spit out a preset file to take across to camera.
Trent, these new custumizable presets and key mapping functions are brilliant. Thank you very much indeed!
May I also submit a proposal?
What about a set of actions to increase/decrease audio input gain. I would love to use the zoom rocker to control my audio levels without having to access the menu.
Hi Trent trying to setup everything again after upgrading to 3.2.8 on my scarlet. I can't seem to get the back scroll wheel on the sidehandle to work even when setting the keys in the menu. It works only after setting it CCW and CW going left or right but it won't function when trying scroll up or down, like in the keymapping menu. Can we have this feature back??
Map a Key to Cycle Through Focus/Edge/Off
