- Thread starter
- #21
greg filipkowski
Sorry man not sure about red one, I did this on the scarlet
George, your camera can't do Red Color 3/Red gamma 3....yet. New build coming soon that will allow that but not ready right now. So you have to view in RAW (no metadata applied) or Redcolor (older color science).Hell, I wouldn't kill you for it. You've read my mind. The out-of-camera footage from our Red-One has always bothered me. I agree with you. I don't care if it is RAW and can be adjusted in post. I want to see it NOW with a lot more pazzaz than it normally would be.
I have set up our R1 as per your settings, but there are a few differences that I'd like to ask you about, since you know more about it than I do. I am still learning this camera.
- The FLUT will only go down to -4.0, so I guess I'll have to settle for that.
- And (I know this is stupid), but I cannot figure out how to change the Red Color to 3 and the Redgamma to 3.
Would you please be kind enough to tell me how to alter those settings in our Red-One so I can get closer to yours?
Thanks again, and I'm sure glad to know I'm not the only one that thinks that way.
Take care.
I would assume the OP was using -0.600 FLUT. -1.000 FLUT would be minus one stop of ISO. -4.000 would be minus four stops.- The FLUT will only go down to -4.0, so I guess I'll have to settle for that.
Many, many projects go this route with no problem. You're essentially creating a mild "best light" (with still enough correctable range for the final), then going to an extreme at the end stage in color correction. Nothing wrong with that, assuming you're doing a Rec709 or XYZ DCP delivery.Well, you can do a two-stage process: get them reasonably close to the intended look, render ProRes 4444 (or 422 HQ, if you can't afford it) and do a mild final grade.
trying to get similar look http://vimeo.com/28550676
Take care.
