Splitter for Epic/Scarlet RED TOUCH 5.0" LCD display to RED PRO EVF.
Toronto,Ontario. Canada
I would like to know if RED by themselves or any third party Epic/Scarlet accessory vendor is working on simple accessory that's the following:
A Splitter for Epic/Scarlet RED TOUCH 5.0" LCD display to RED PRO EVF.
I do not think it's possible to split the signal since they work with different resolutions (i think) so the solution pointed at by matt is probably the only way to go. There will most likely not be a 1 to 2 cable for both monitor and evf feed from the same socket wich is what I guess you are asking for...
