Ian Vertovec
- Jan 5, 2009
One of the best things about projecting at this brightness is we can essentially just color in 2D, then 'push' the grade to the 3D version. Which is essentially what we did with LOOM.
If you are planning a release with modern, 4ftL, then you have to do a '3D trim' which is just completely comprising the entire look for dark viewing conditions. Hopefully with Laser technology we'll actually be at a point where the 2D and 3D versions look the same because they actually WILL be the same.
