Jim Brennan
Two challenges:
I have a sequence of 4K and 2k (shot 2:1 and output from Redcine to FCP as prores 422 files) that I was told needed to be exported to an SD DVD, so I set my sequence settings to DV NTSC and outputted via compressor to DVD
Now they want an HD QT file, which leaves me to solve two problems.
One: I figured the best way to output would be as a QT file using prores, but I can't seem to find a setting that would maintain the aspect ratio (although I would be willing to crop if I have to). I'm definitely open to suggestions there.
Two: Since the original sequence was set to DV NTSC, I am outputting with those dandy black bars in a 4:3. Is there a way to output at the 2:1 (or whatever I crop to) from that sequence?
Thanks in advance
Thanks in advance
