IR Pollution Fix
Just like Peter Majtan says, that's the order you want. And you're not going to get effective IR blocking at the level you need in front of the OLPF. Not going to happen because it would need to be a hot-mirror style filter and would be reflective. Let's also not forget that some newer lens designs made for mirrorless systems (like the Angenieux DP zooms) already place their rear elements very close to the OLPF layer as it is. You're not going to stick another filter in there.
Filtration works best IN FRONT of the lens. If you want to put anything behind the lens, that's best reserved for diffusion or distortionary materials; netting the lens and whatnot. The exception being lenses with drop-in trays or rear-mount filter holders that are designed to accommodate an extra optical layer at those positions.
When shooting any digital camera at high ISO (320~800 and up) you are going to be more susceptible to IR contamination with heavy ND, this is not a problem unique to RED. But the way RED captures the image and floats ISO as a meta-quality in RAW without using analog limitation or gain as many other cameras do, we find ourselves reaching for more ND when shooting in intensely lit environments. Not all environments have the same amount of IR bouncing around. And not all lenses transmit IR the same way. So you need to test with various combinations of lenses in your intended shooting environments or approximate them as close as you can. And test different filters and combinations. Yes, this can get expensive at times... I often shoot in some pretty intense IR and UV environments and don't usually encounter many problems. I have the best luck with Formatt IR+ND filters.
Also, one thing to note in regards to polarizers. They often lose their effect or can cause undesired results when used in combination with IR or hot mirror style filters. Polarizers are one of those filter types that like to be up front and work best when they are. Unfortunately that isn't compatible with IR-cut or hot-mirror filters. Test.
Final thought / opinion. When it comes to stacking filters in front of a lens... less is always more.
Jeff is spot on - the order I have posted on the previous page is just that - an order - I would never use more then 2 filters, so just pick two and put them in with the relation order in mind.
One reason why I like 2-stage MB's - it forces me to think twice...
Peter
I'm with Jeff. I've tested literally everything out there fairly recently and I'm holding on to my Formatt Hot Mirror/ND filters. They have provided the best color and good optical performance.
If you guys haven't been following my "Skully" thread, here's a sample image against the Schneider Platinum IRND:
Remember that at deeper filtration, usually 0.9 and above, infrared protection is really needed.
The color of the browns, greens, blue sky, that white ledge on the middle building, and shadow detail is what helped guide my decision.
Just a newbie question:
IR filtration and Hot Mirror these are NOT the same things, right?
From what I understand, Hot Mirror fixes the red reflection of the sensor itself in the center frame, while IR filtration helps IR poilution when adding strong ND.
Have I understood this correctly?
If this is correct, then is it possible to buy Hot Mirror only filters?
(I´m asking this, because I just ordered three expensive Tiffen IRND filters...but no Hot Mirror is mentioned :( )
I don't work for any of these companies, but from just looking at the Tiffen IRND filters themselves you can tell there is no Hot Mirror in there. In fact, whatever they are doing was done to decrease the cost of the filters and make them affordable. Whereas mating the Hot Mirror with the ND tends to cost a bit more dough.
Here's their little doc on the IRND stating no Hot Mirrors are employeed:
http://www.tiffen.com/userimages/IRND-FullSpectrum_SS(1).pdf
Interestingly enough, in 2008 they had a "HMIRND" in the works:
http://www.tiffen.com/press_release_Hot_Mirror_IRND.htm
Though I haven't ever seen one of those. It's two different ways of trying to eliminate IR. I don't know exactly what optical formula Schneider and Tiffen are using, but I do understand Hot Mirrors, what they do, and know they eliminate IR pretty damn well.
I first used Hot Mirrors on a CCD that was used to scan Super35 film at 4k way back in 1999 before the Northlight scanners were released. Oddly the Epic/Scarlet remind me a lot of that device in terms of infrared protection.
I've never seen that on a 5D. I believe that RED choosed not to be so aggressive in filtration as do many other manufacturers that have more a consumer market. RED is a professional tool after all, professional should know their tools.
Well, I'm still scratching my head to choose THE filter for exteriors. I dislike HM due to their mirroring effect, in lens AND even on actors sometimes...
Pat
PS: do you put the mirroring pink side of the HM filter towards the lens or toward the actor? Thanks.
I don't really have a problem with "Bulky" matte boxes when I'm shooting outside… They serve a bunch of purposes beyond just looking cool and getting in the way. Also it just seems way easier to me to swap out a filter in a tray in the matte box then to pull the lens and fuss inside the camera because an outdoor lighting situation has changed or the director has called for a different look. (and then have him / her change their mind again)
Just how I feel.
G.
Phil, can't remember if I asked you before but can you post a link to the Formatt filters you're using? And is it my understanding that the hot mirror is built into the filter, or is this a separate filter? Thanks
The only problem is...high quality IR filters are made of unobtainium....other than that, great idea
