RED SCARLET-X on Steadicam Zephyr BTS
I use the Zephyr with my Epic and you can make the rig much lighter. First and foremost, have a cable made to power the Scarlet from the sled and get rid of that V-lock battery. Then try without the mattebox. If you aren't using filters then it probably isn't doing much indoors, assuming you aren't getting weird reflections.
My Epic rig is more like 13 pounds and is very easy to move around.
Hi, thinking of buying Zephyr too. Can you share experience on this things:
What is better for use with Epic/Scarlet - compact or standard vest?
Did you get better picture/power ratio with Marshall monitor then Steadicam monitor?
Thank you
Jim, where did you get your power cable for the zephyr stage and epic?
+1
I'm wondering how to power an Epic-M directly from the sled of a Zephyr? I've seen some cables on Tiffen's website that turn Lemo 3 Pin to Lemo 6 Pin for the Red-One, but that would requiere another cable like the one RED has on their store to adapt it for the Epic (http://www.red.com/store/power/product/2b-to-1b-lemo-power-adaptor-cable)
I'm sure their is some better configuration around, but I just don't find them... if anyone has any idea :)
can any one help me in calculating weight for scarlet x
1) scarlet brain al canon mount
2) ssd recording module with 64 gb card
3) 5" touch screen monitor with cable
4) ssd side handle with red volt battries
i am planning to buy glidecam 4000 pro model which supports 10 lbs
I'm also looking for a single stage solution to power my Epic off the Zephyr sled. Called Abel Cine, and don't seem to have any ideas beyond use two cables, or look around. Doesn't seem to be a lot of info around. Called Tiffen, left a message... Hope they get back tomorrow, but anybody got some ideas?
If you need any steadicam related cables, Terry West is the guy you want to call (or email).
Here is his contact info.
310-374-5711 or techrat531@verizon.net
If you are in Canada, David Harble at Cramped Attic has some Epic/Scarlet Lemo power connectors and he also builds cables for steadicam.
604-254-8619
hable@telus.net or crampedattic@gmail.com
Just ordered a cable from Terry West. Agreeable fellow! Thanks for the referral.
