Adrian Jebef
- Jun 25, 2010
- Los Angeles, CA
- adrianjebef.com
Absolutely not, the Alexa has a nice output image but in terms of pure color rendition the Epic wipes the floor with it. Including skin tones. However with more information comes greater responsibility and the need for greater understanding of the material and processes required to control and manipulate said information. If you like your images spoon fed to you the Alexa/C300 etc. are a good fit. If you want full access to what is really there the only choice is Epic.
My second contention is that saying a GRBG Bayer filter array is 4:2:2 or 100%/50%/50% is like saying that a 4 cylinder is 30% less powerful than a 6 cylinder. Despite the fact that the 4 cylinder is a tuned Subie STI and the 6 cylinder is a Camry. Debayering is a computational act, it uses real, interpretive and calculated information to create color channels that measure much higher than the 4:2:2 or 100/50/50 you imply because no color is absolute, it is made up of components and those can be calculated to a much higher degree of accuracy. Measured chroma resolution here is the important thing to consider because that is the chroma resolution actually available to you when you debayer and process your footage. Is in absolute terms the color resolution lower than the luma? Yes, but by only a small margin and at least at 5K you'd be getting around 4K or more, again tested, usable, measured resolution, not theoretical numbers based on a sub-sampling method that doesn't even apply to RGB. Remember YUV is in and of it's self a chroma subsampling method.
Simply by staying in the RGB space you've saved significant color information from being thrown down the drain.
Put into YUV terms if the Alexa produces a pure 4:4:4 image (It doesn't but I'll go with it) then the Epic produces a 20:16:16 image, which would you choose?
Evin:
It has been my experience that ALEXA and F35 footage has "truer" skin tone reproduction than Epic footage. To me true color reproduction should allow for what is seen by eye on the set to be translated to what is seen on the screen. In order for this to happen a whole lot of technical crap has to happen first. There are steps to the process. Light energy needs to be captured. That energy needs to sampled and then converted (analog to digital) to a numerical value representing the intensity of that energy. This is then scaled into the degree of accuracy of the system: 8-bit 256 values, 10-bit 1024 values, 12-bit 4096 values, and so forth. At this point it is RAW and it can be recorded. This is what the Epic does and what the R3D file represents. But is is not an image. It is not what was seen on set. These numbers need to be crunched, algorithized, transformed, debayered, reborn, interpreted. Debayering is a computational act. It is math. And it does use "real" (discreet), sampled information but it also uses interpretive and calculated (non-discreet) information to turn the math into an image. My experience has been that the accuracy of this process is relative to how the image was discreetly sampled at the sensor. Math can be re-calculated to get slightly better results but math cannot add discreet values that were never present in the first place.
The Epic is an excellent 4K black and white camera. But it's color reproduction I find lacking. The idea that the end user must take on more responsibility and a greater understanding of RED's "mysterious" image-making process is simply silly. Yes, RAW image data can be computationally changed an infinite number of times without (theoretically) destroying the underlining data. But RAW image data cannot "magically" produce chroma resolution that wasn't there (sampled) in the first place. RGB, YUV, XYZ, or ABC do not really matter as they are simply quantitative spaces in which the RAW data will eventually inhabit. Just because I have a 16-bit RAW file or a 10-bit RGB image does not mean that I have all of the luma and chroma information that was originally present in the scene at the time of capture.
I have no interest in which camera system provides bigger and better technical results. My interest is in the system that provides results that are as close to what I see by eye.
BTW: if we say the ALEXA is 4:4:4 at 2K/HD and the EPIC is 20:16:16 at 4K then wouldn't your logic lead us to declare the EPIC is 4:2:2 at 2K/HD?
