Steve Yager
I'm not sure I understand the difference between the look presets and the look manager in RCX-P. Can someone explain when I'd use one and not the other?
A clip can have multiple looks associated with it -- the Look Manager shows you what looks are bound to the current clip in the Viewer (all the looks shown are saved into RMD flies).
The selected look in the Look Manager is the "primary look", that is, what you see in the Viewer is the clip with the primary look applied.
Look Presets, on the other hand, are not bound to any particular clip. Any clip can have a look preset applied to it.
So:
* Create a look preset if you want to save a particular look and later apply that look to other clips;
* Create a new look in the Look Manager if you're not quite sure what look a particular clip should have, and you want to quickly switch between different looks for that clip.
Most of the time you'll be working with look presets only.
So you can't apply a look from the look manager to another clip?
