Steve Sherrick
Can only get as low as 6:1 on Scarlet at 24fps in 4K.What???
Scarlet also has low compression,
as in, low as 3:1 just like the EPIC-X.
I suppose if you wanted to shoot less fps you could get down to 3:1.
Well it seems most users agree that 800 ISO is the best to shoot at, even outside.
So when you guys are shooting with daylight balanced LED's, what are you doing to combat the green spike? I know most sill use minus green filters, but that didnt really seem to help all that much. I have never seen my Rosco LED's look so green before on any other camera.
I really do appreciate all the opinions and feedback. This is just one of the many reasons why I chose RED.
Gunleik,
When are you going to write a book?
Watch the histogram and the goal posts. Expose as far to the right of the histogram without clipping and you can bring everything down in post. As for color temp, the lower you go the more noise your going to get unless you expose it perfectly.
Noise goes away if you crush the blacks.
"As for color temp," you are talking about the Kelvin? I was under the impression Kelvin was just meta data, 3k, 5k, 8k, you can change it anyway you want in post.
Sure, but that does not mean it doesn't affect your image and noise. Last time I checked, the sensor stays the same, whatever metadata we use, and the sensor has some preferenses.
G
My thought was that since it is meta data, you can set this at any value and in post get what you want. So in that light, it would not effect the noise which obviously is incorrect. Changing the Kelvin in camera DOES change the noise floor?
The simple answer - the shot isn't exposed properly. Also, be careful of color temps of your lights.
