Costelloe Michael
Thanks John,
Good work.
Mike C
Good work.
Mike C
This is brilliant functionality that few of us knew about. One of the things that makes this forum great is sharing this kind of knowledge. I uploaded your preset this morning to use with my ultra light weight handheld set up on Monday. I really like it. I can't seem to get to the alternative menus needed to change the view or eject the media. Can this be done? Am I missing something? Please advise…
John, thank you so much for sharing! Thank you Red for making it possible.
Toggle between menus or 'back' from a submenu = Both 1+2 together on the side SSD
There are multiple ways to get back to the original key mappings:is it easy to go back to the original presets? Do we need to back up something before uploading this presets? I don;t have my EPIC yet so i don;t know how it works.
Also, does it work with the old EVF?
But it sound like a great tool.
Thanks for sharing.
I have still yet to find a way to enter/exit 'playback' and 'format' mags without the touchscreen.
You can use the side handle or REDmote to navigate the menus if you don't have a touchscreen.
Enter Playback:
SETTINGS->PLAYBACK
Exit Playback:
SETTINGS->RECORD
Format Mag:
MEDIA->FORMAT...->FORMAT
So, If I only got the brain and ssd and evf, no redmote or touch lcd or side handle, can I shoot? format cards?
I'm pretty sure that was the point of the original post. A pretty ingenious key mapping preset that let's you navigate the menus (and thus perform any action on the camera) using only the buttons on the side SSD and the EVF.
The only problem is how you would initially load the preset if you didn't have any other input method. Luckily we added a feature in 2.0.8 (currently beta) that lets you automatically load a preset file on boot up by placing it in a folder named "force_preset" on the SSD.
Hopefully that answers your question.
Yes, you can enter/exit playback and format media using this preset. The reply I gave with the menu trees to access those features may have been a bit confusing because I explicitly mentioned the side handle and redmote. Instead, I should have said those features are accessible using the menus (and not just with the touchscreen).
Enter Playback:
SETTINGS->PLAYBACK
Exit Playback:
SETTINGS->RECORD
Format Mag:
Thats what I thought until I read this, so I thought maybe you can't do those things without one of the three (redmote, touch lcd or side handle)
I ordered redmote but should get it after the epic so I wanted to know if I will be able to shoot without any of the three.
So, I understand by your last reply that is ok including playback and format, right?
Thanks a lot!
