Mark de Blok
- May 12, 2008
Where is Hanksville?
Mark are you using 2 x NP1 Batteries to power your Epic ?
totally no problem with a V-Mount adapter... we also do so as we have lots of these "lying around" from our DigiBeta/BetaSP/DVCAM-Days... You only need a single or (better) dual adapter for the NP-1's and you're good to go! Maybe not the smallest package to run with - but works totally fine! Hot-swapping is no problem when running with 2 of these, only downside is you can't really estimate the exact "down-time" as you only have the voltage-reading and no percentage-reading. But totally no problem to handle this.Mark are you using 2 x NP-1 Batteries to power your Epic ?
