Epic can't power up
bert tan
61
singapore
www.bertlightinghouse.com
Hi ,
Tried to record on SSD card, timecode was running but in blue and no red recording indicator on top right corner. Played back footage from SSD card and Epic shuts down halfway. There is still power in the battery and the red battery indicator light is on but no way to power up at all.
Please help shooting half way . Thanks
Hey Bert, what software build are you on? Try powering up from the ac power supply.
If you can pull off a log file, can you email that to me?
deanan at red
How do i pull the log file ?
Under maintenance in the ui, there's a save log function. It'll save a file to the ssd called 102-xxx-xxx.txt.
Email that to me (deanan at red dot com)
Hi Deanan ,
The camera can't even turn on and i can't pull a log file .
bert
Hi Deanan ,
bert
Below you mentioned you're seeing timecode.
The description is a bit confusing. That was before?
Can you try putting the 1.7.10 firmware on the ssd ("force upgrade" folder) and power up?
Hi Deanan ,
Yes that was before the camera shut down by itself .
I have try to load 1.7.10 firmware but it still can't turn on .
cheers
bert
Hi Deanan ,
cheers
bert
Can you email me and I'll get the support side involved directly.
This happened to me the other day. Was able to force upgrade the firmware (to the same version already on there) and that fixed it.
Hi Jim,
Which firmware you use ?
bert
