Adam Johnson
SIAP: But I have not seen this anywhere else. Please post your best Monopod options for Epic and Scarlet here. Pictures recommended!
Thanks,
Adam
Thanks,
Adam
Carbon Fiber Gitzo.
Sure, but you don't need one quite that stout for a run and gun setup. Mine holds 17+ lbs. and is more than sufficient. Look for something around the 20lbs range and you should be fine. Not sure what Mark Toia has, he'll probably chime in here with an update.
Avoid the monopods with a 3/8 sleeve that surrounds a 1/4-20 screw.
So is it safe to assume the Carbon Fiber Gitzo's rated for 20+lbs should fit the bill?
AJ
I love mono pods... takes me back to my old photographer days.
Using a mono pod with a 300mm
http://www.zoomfilmtv.com.au/ftp/JUNK/RED_Surf_quicky_test.mov
This stuff made me want to go surf, Very nice work for 5 minutes, that is less than one battery... We should all do a "best Red Volt" photo challange, to see who can make the nicest short using only one VOLT without recharge![]()
55lbs is overkill for sure. What is a cheap, secure mount to use between the monopod and Scarlet. I'm used to simply screwing the round mono pod plate into the camera directly, but I will have a Easy Riser plate (at the least) between camera and monopod for follow focus. Do you think that is secure enough? My camera rig will probably be 15lbs (maximum)
