it was working perfectly and now for some reason i cant get the export to match what ive graded. attached is a pic with the settings the window and the exported frame. if anyone could help that would be fantastic.
How are you exporting? Clip in Viewer? Or Clip in Bin? Dragging a clip from the Browser to the Viewer and grading it will not affect the same clip in the bin (as they are different instances).
David,
are you saying that if we grade a BUNCH of clips in RCX Pro from the bin.....and of course grading in Viewer or via Rocket out to monitor...then we go to Export/Transcode Clips from Viewer----we DON'T get the graded look? or can you elaborate further....so, open a disk, or mag....then grade them....Please elaborate.
One common issue that pops up is that of order of operations. It's really only a convenience that you can go directly from Browser to Viewer. That is fine if you export straight from the viewer, and auto save RMD is not necessary for exporting.
If you drag a clip to the Bin, then double click (or drag) that clip from the Bin to the viewer, you are good. Again auto save RMD not necessary.
If however you go from Browser to Viewer, but then also go from Browser to Bin, continuing to grade the clip in Viewer, this is a problem.
Ryan it sounds like you've encountered some sort of bug. Can you email verbose log files to redcinex at red dot com? Make sure the logs capture you trying to transcode a file that hasn't picked up your grade.
Thanks,
David
EDIT: Just looked at your screen shot again ... that export definitely has the grade applied, but looks only slightly darker. Can you email a high res screenshot as well?
David, it's like you are saying that when performing the latter operation....From Browser to Viewer....then one is NOT saving an RMD....is this what you are essentially getting at? Grading a clip and NO RMD file associated with it? Because as i recall i grade ALL my footage from my HDD and leave in those locations....i don't move anything around to bins etc....then export. I'm not aware of how this can affect my final transcode.
OR....i think what i'm trying to say is my grades are FROM the browser...where i just click on the Mag, then those individual clips show up on right side---i presume the Bin---i'd have to look today to see if i have all the correct names: bin/viewer/browser.
im not framiliar with how one generates a verbose log or where its located once created.
also interesting thing is happening. i apply my saved look to the clip in viewer (that was opened in the bin, then double clicked to open in viewer) and it looks like i want it. then i preview the "meta" look and it switches to the darker weird look automatically. kind of strange.
You will always save RMD if auto save RMD in enabled, regardless of how a clip ended up in the viewer. For the purposes of transcoding though, it's not necessary to have an RMD file, as the correct information is saved in memory.
So for your first scenario, Browser to Viewer, grade, export "Clip in Viewer" you are absolutely fine, and there is nothing wrong with this. Just beware what I outlined above .. it can be a simple mistake to make, especially for those new to RCX.
If you right click on a finished transcode you'll have the option to "Show Log in Folder." You can zip up the entire folder if you want and email that.
If you are previewing the meta look, it should switch to the meta look, and then switch back to the currently applied look once you let go of preview. Are you not seeing this behavior?
ok, so i restarted just in case.
1. i find the r3d file i want to adjust and open it in the bin. i double click that file to open in viewer. i apply the meta look to get back to zero. i have a saved look that i like for this clip so i click and hold the preview button and it looks like i want it to look, then when i release the button the viewer has applied a very dark look to the file. so i apply the look that ive saved and the viewer's image again looks like i want it. then i preview the meta again and when i release that button the footage in viewer again reverts to the weird darker look.
it almost looks like the weirder darker look is the look i saved applied twice to the same file.
ill do another export and send the log and the high rez file to that email.
figured out what was happening, though i have no idea why.
for some reason when previewing "META" or when exporting, redcine x pro was turning on the alchemy switch which i had de-selected for my saved look but had left at the +.794 that i had been experimenting with earlier creating the weird darker look.
i exported with the alchemy zeroed out and deselected in both check boxes and the exported file has the correct grade applied.
