TACTICAL TOP PLATE
Works with Epic-X but current Ms?
Works with M's with the old tops but only using the front bolts. All M's that are out there being upgraded over the next couple months to have the rear holes.
The side SWAT rails will provide rear support ( coming soon ) if you need some heavy lifting.
Will be in the store soon.
Yup Holes in front :)
If I flipped a DSMC 19mm Universal mount upside down could I mount it to those 1/4 20's? on front or back? Not imperative but options, esp for run/gun are always good.
Jason
the rod spacing for 19mm rods is not wide enough to clear the top plate if you mounted it on the front or back.. you need to bolt it to the top of the plate instead using a riser.
I'm assuming that one of the holes will allow the back focus adjustment. Would be great if its marked like Brook's design. Can't wait to see more of the tactical system.
Jarred, Does it work with DSMC TOP MOUNT 19mm or is it one or the other? I'd like to have top rails and a top plate.
Jarred how will side rails connect to the EPIC bottom mounting plate without changing height?
Will you be able to put it on the clutch without having to change plates?
This is my issue with purchasing the clutch at this point with Brooks FMJ (unless there is a way to use the FMJ with the clutch?)
