Jean Guerra
- Feb 10, 2007
- Dominican Republic, Santo Domingo
what lights should i use when shooting at 300fps????
I often use DC power when shooting High Speed. No Flicker. Tungsten lights. Maxis, 20K's, Mole Beams. Parcans, Etc.
I wrote about lighting for High Speed a while back in reference to Phantom cameras. Check the bottom of this link:
http://multi.abelcine.com/resources/2009/06/18/phantom-hd-faqs/
In general, we have found that lamps larger than 2000 watts use tungsten filaments so large that they do not have time to cool and dim before the power cycles back up. Therefore, we recommend using 2K or greater tungsten light fixtures when shooting above 120fps in 60hz countries and 5K or greater when shooting above 100fps in 50hz countries.
Hello Mitch,
Thanks for your article. I actually didn't understand why it's ok to work on 2kw Thungsten/120fps in 60hz, and it has to be minimum 5kw Thungsten/100pfs in 50hz?
Pat
Twice as many amps in the US is the simple answer. A 100w dedo @ 12v is roughly the same as a 2k in Europe in flicker terms. Of course if you run the dedo of a car battery then it wont flicker at all!
