Yes.. on the side handle there is an X-sync port for triggering long duration flashes.
Hi Jarred
Can you recommend some long duration flash makes/models?
E
One of my biggest questions in all of this is the problem of producing sharp stills with a model leaping around a studio. Excuse my ignorance but could someone please explain
"Now with EPIC and HDRX you can shoot one track for motion, and use the HDRX shorter shutter track for sharp stills"
If that works - WOW because that has been my only issue about using this camera for both. My clients want stills from motion this could hopefully be the last piece of information I need in the jigsaw.
"If the exposure is 48 Fps with a 270 degree shutter the +1 HDRx mode will yield a 135 degree shutter." Stephen Williams
NOTE: Double the 270 degree shutter would be 540 degrees, NOT 135 degree shutter that would be half the shutter speed. If that were the case there would be more “Motion Blur” not the intended circumstance. A 135 degree shutter is actually -1 while a 540 degree shutter is +1.
Humberto Rivera
Like Humberto, this seemed counter-intuitive for me as well. And like Humberto, this continues my confusion. :undecided::confused5:Humberto: You are the one who misunderstands. HDRx setting +1 means you are capturing 1 full stop lower exposure, in order to capture 1 more stop of highlights. The x-track is always DARKER and needs to have exposure boosted in RED CINE-X order to look normal.
+1 would be a narrower shutter... or a shorter shutter duration. I.E if you shot 1/48 on your normal track, +1 on the HDRX track would be 1/96.
Pardon my continued persistence in this matter, as I wrote in a previous post! “The “A” track is the primary exposure track, as if shooting regular well exposed film. The “X” track is selected in portions of +1, +2, +3, +4, +5, and +6 it’s twice to shutter speed to six times depending on the number setting for the “X” track. Both the “A” and “X” tracks are on a single R3D frame. (Recorded Simultaneously) The camera is using the normal 24 frames per second settings set in the “A” track; ONLY the SHUTTER SPEED for the “X” TRACK is the one CHANGING VALUES. All the rest of the options are in post-production.”
A QUESTION! Is the faster shutter speed a lower value; 135 degree shutter at +1 or is it 540 degree shutter speed?
Humberto Rivera
If you are shooting the A-track at 270 degrees and have a HDRx setting of +1, the equivalent shutter of the x track will be 135 degrees. That is, the exposure of the x-track will be 1 EV lower at a setting HDRx setting of +1. BUT, HDRx does not take two separate exposures, one after the other. RED has not been clear on EXACTLY how HDRx exposes the x-track, but as more info comes out about things like a need for long-duration strobes, it seems pretty clear that it reads the sensor line-by-line twice. The mechanical equivalent would be to have two sets of shutter curtains - each generating its own exposure and swiping across the sensor at the same time. Of course, this would be physically impossible since the narrower curtain would determine actual exposure, but that's the magic of digital.
So, skew would be the same in the A and X-tracks, while motion blur would be different.
Also, since the +1, +2, +3, etc. settings refer to EXPOSURE VALUES or additional EVs of highlight capture, the effect on equivalent shutter speed is exponential. +1 cuts shutter speed of the primary A-Track in half (270 degrees -->135 degrees), +2 is 1/4 shutter speed (270-->62.5), +3 is 1/8 shutter speed (270-->31.25), etc.
HDRx was primarily designed to extend DR in motion. The fact that you could use stills from the x-track to freeze motion came out pretty early in the theoretical discussion that ensued when HDRx was announced. The ability to do this well is also enhanced by another feature of RED, which is that ISO is metadata. This means you can take an underexposed still frame from the x-track, and boost ISO in RED CINE-X and come up with a normally exposed still. Of course there wil be limits to this, but pretty amazing!
