Ruben and Sheri O.
It's how ur talents are not DOF , Kubrick saw to that by having deep focus on alot of his films. Scarlet will be a winner in my opinion, and if u want DOF buy an EPIC.
But we have had this conversation so many times..........................................................
All this has happened before. All this will happen again...
I think there is some confusion about what a deep depth of field means because Kubrick's color films did not generally have a lot of depth of field except outdoors maybe when he could stop down a bit. He often shot near wide-open to maximize use of available light. "2001" in particular has some very shallow focus shots due to the 65mm format and the fast lenses he was using. Look at David Bowman's close-ups inside the pod for example. What Kubrick had was a lot of wide-angle shots and he played a lot of scenes in wide to medium size, so the shallow focus from using lenses at wide apertures was not very apparent except in close-ups. True "deep focus" generally means holding sharp focus from very near to very far in the same shot. Kubrick did not light sets to deep f-stops in order to get deep focus, he often was shooting at f/2.8 or wider. Most of that Kubrickian look (and Coen Brothers look) is due to the use of wide-angle lenses, some extreme, not due to working with the lens stopped down.
Its cheap enough so I can set one on unattended record to capture a whole stage and then get all my coverage with the other camera I am using ... even if that is a 7D. 2 fixed and a Scarlet Cinema with a nice ENG zoom may be a good package for covering events as well.
Just curious, does anyone know what the continuous record time spec'd for Scarlet is? I had issues with other small HD cameras' fat32 4gb file size limitation . For continuous unattended recording, this may be important. I would also kindly advise against leaving highly anticipated yet to be released camera unattended![]()
