Alexander Ibrahim
The first picture is exactly what i meant by it.
so your saying its achieved using a powerful source behind the actor? Because to me it appears a large blast of light is coming from above.
I see this as a point in a continuum of the same technique as in the second still. I threw that second picture in merely as a clue, but not a direct map to creating the exact result you are after.
The rim light is created by a light on the far side of the subject and above the subject.
(My convention is that elevation 90º is directly above the subject. -90º would be directly below the subject, and 0º would be on the plane with the camera and subject.. In all cases the source is aimed at the subject. I wonder if there is a more universal convention for these sorts of discussions.)
In the Inglorious Basterds still I posted the rim light is coming from behind and above the actors at roughly 50º.
In the JFK shots David posted its coming directly down. I'd probably have set it very slightly tilted, perhaps 85-89º ... but its the same idea.
What I don't know is if I'd be bold enough to let that much of the image blow out. I think it would be very dangerous in digital, you'd have to control it much more. The Inglorious Basterds lighting seems much more like what I might aim for with digital imaging.
