Evangelos Achillopoulos
- Apr 10, 2007
- Athens, Greece
- www.motionfx.gr
Andrae, Ido for years is using my services, as well as Luis... if you want the cheapest solution just go to the generic LUTs that I provide and you have it all... otherwise the digital only consulting package will give you access to CineProfiler also... Check out the movies we have done with Ido... http://www.motionfx.gr/client-work.html
Mike is correct to go to your filmout facility for that, but most of the time there is a conflict of interests and these (Filmout DI facilities) guys don't serve others easily... especially if the free service includes the secret sauce...
There is where I fall in to the picture...
Also to work in the limited gamut of video and then use inverse to go back, like "do it in REC709 and we will fix it" attitude... is not quite productive as if you use the wide gamut of film calibrated environment and then just convert to video or DCP... you know better, that we Pro DI houses, we use film first and then everything else... As about compromises... I see more the opposite way... Rce709 and the film... the way video and DCP is encoded doesnt allow the same depth of colors like film does... you aslo know that...
On the other hand, yes, the digital is here to stay... film dies, lets try to forget how it looks is a new approach... an approach I don't agree with...
If everyone see the differences in this page they will understand why film as a primary grading target is better...
http://www.motionfx.gr/workflows-lut.html
