Marc Baleiza
- Feb 22, 2011
SO... Red Rocket Breakout Box, received this morning from FEDEX. After receiving, I updated RED ROCKET CARD to the latest driver, then firmware, then the firmware on the Breakout Box and rebooted it as per instructions.
When I am outputting RGB, I get a Green and Pink picture on SDI1a and a different Green Picture on SDI1b. I believe this is the 422 and 022 pictures from previous reports, playback all good. When I send a YUV422 8bit image I am getting a green picture with severe breakup. Please see attached file. The image plays back in realtime - but with this green breakup.
I have tested the SDI out on the Red Rocket Card directly, and it does not have the same problem. Which leads me to believe there may be an issue with the new firmware on the Breakout Box, or the Breakout box itself.
I am on a 2 x 2.4 Ghz Quadcore Intel Xeon MacPro with 6GB of RAM. Mac OS X 10.6.4. Running the latest build of REDCIne-X.
I have tested both REDCine-X and 32bit and 64 bit applications and am having the same problem. I have also rebooted, reconnected etc.
Any idea's would be much appreciated.
