Steve Phillipps
If R3D material is transcoded to ProRes and edited, presumably you are more limited in terms of colour correction and other adjustments than you would be with the original RAW files. So once you've done your offline, is it possible to reference the shots in your timeline to the original RAW files, process the RAW and then replace the shots in the timeline with the processed versions?
Steve
Steve
