Eric Santiago
Exactly what I want to hear
Exactly what I want to hear![]()
For what we need it for the MC Color is perfect. Im already using it with REDCineXThough the Resolve panel still kicks its ass.
That's the only caveat - this isn't a "mini Resolve panel". Maybe I was getting my hopes up a little too much.
So if you're budgeting for a MC Color vs the full Resolve panel, I say you definitely want to give the full Resolve panel a look because it is more streamlined.
Bruce Allen
www.boacinema.com
Has any one tried using Resolve with FCP X? If so what is your current work around to get around FCP X's lack of XML? Thanks!
AFAIK there is no workaround at the moment - BUT Resolve has excellent edit detection if you just feed it a ProRes file.
Automatic Duck works with FCPX, creating AAF, which Resolve 8 understands. Problem solved... at $495![]()
I'm a little leery of spending $495 for an add-on to a $299 program I'm thinking of getting a refund on.
They advertise it only for audio...
EDIT: ah - it seems to have an option to "reference video files" ?
http://www.automaticduck.com/user_guides/PEFCP5UserGuide/SettingsX.html
Dont get too excited. Its still AAF and/or OMF. Which are audio centric interchange formats. Any associated video is not relevent from anthing other than being used as a visual reference in Protools/etc.
Right you are. I stand corrected on AAF. Not on OMF
Jake Ive been meaning to ask you, have you ever worked with a Flanders? Im sure your used higher end (and cost) ones but I had to ask. Sorry for the off-topic.Actually you're wrong again![]()
From Automatic Duck page:
The OMF (Open Media Framework) file format was once promoted by Avid as a format to replace EDLs as a way to interchange media and edit information between digital video and audio editing systems. OMF gained acceptance amond Digital Audio Workstation (DAW) manufacturers like DigiDesign, Fairlight, MOTU and Steinberg but somehow didn't see the same level of adoption between video editor developers. Probably because of this history many editors equate OMF with audio, but the OMF file format was also capable of transerring picture edit information as well.
Having fun Jake? :smile5: That may be so, but in practice, not theory, OMFs are not generally used to move picture edit info between apps (say FCP and DaVinci Resolve for example). There are many reasons for this. And the use of OMFs are almost exclusively used today to move audio from NLEs to ProTools (or other DAWs) in 2gb chunks. This includes Automatic Duck.
To stay on topic, when is version 8 coming out? I have an MC Color feeling lonely hereIts okay since RCX seems to get some time in
